Translucent Plastic
Hi Guys.
I need some help creating this type of plastic. I tried every type and just cant get it to work.
I think I’d typically try a cloudy plastic for that kind of thing. What specifically is it that you can’t get to work?
Things to check-
  1. projects scale- to make sure all measurements and numbers in the materials make sense
  2. lighting- change lighting around to make sure you have good light source to penetrate the plastic
  3. Try different render modes, product vs interior
can also start with some of the great materials in the keyshot cloud and see if you can get close, I do that a lot and tweak from there.
Scale of the object matters a lot, but here are settings I am using for a standard size table top bottle. I haven’t really played around lighting as it is just using the startup HDR, but it will effect the final appearance immensely.
